HOW TO
This article provides an Avenue example of how to retrieve statistics for all numeric fields in a table and display them in a new DBF table.
Code:
RESULTFILE = FILEDIALOG.PUT("result.dbf".ASFILENAME,"*.*","FILE")
RESULTVTAB = VTAB.MAKENEW(RESULTFILE,DBASE)
RESULTTABLE = TABLE.MAKE(RESULTVTAB)
F1 = FIELD.MAKE("FIELD_NAME",#FIELD_CHAR,12,0)
F2 = FIELD.MAKE("Sum",#FIELD_DOUBLE,12,5)
F3 = FIELD.MAKE("Count",#FIELD_DOUBLE,10,0)
F4 = FIELD.MAKE("Mean",#FIELD_DOUBLE,10,5)
F5 = FIELD.MAKE("Maximum",#FIELD_DOUBLE,10,5)
F6 = FIELD.MAKE("Minimum",#FIELD_DOUBLE,10,5)
F7 = FIELD.MAKE("Range",#FIELD_DOUBLE,10,5)
F8 = FIELD.MAKE("Variance",#FIELD_DOUBLE,12,5)
F9 = FIELD.MAKE("Standard Deviation",#FIELD_DOUBLE,10,5)
RESULTVTAB.ADDFIELDS({F1,F2,F3,F4,F5,F6,F7,F8,F9})
theTable = av.GetActiveDoc
theVTab = theTable.GetVTab
THEFIELDLIST = THEVTAB.GETFIELDS
for each THEFIELD in THEFIELDLIST
FIELDTYPE = THEFIELD.GETTYPE
if ((FIELDTYPE = #FIELD_DECIMAL) or
(FIELDTYPE = #FIELD_BYTE) or
(FIELDTYPE = #FIELD_DOUBLE) or
(FIELDTYPE = #FIELD_FLOAT) or
(FIELDTYPE = #FIELD_LONG) or
(FIELDTYPE = #FIELD_MONEY) or
(FIELDTYPE = #FIELD_SHORT)) then
thePrecision = "d.dddddddddd"
theFieldPrecision = theField.GetPrecision
Script.The.SetNumberFormat( thePrecision.Left( theFieldPrecision + 2 ) )
if ( theVTab.GetSelection.Count = 0 ) then
theSet = theVTab
else
theSet = theVTab.GetSelection
end
theSum = 0
theCount = 0
theMinimum = nil
theMaximum = nil
for each rec in theSet
theValue = theVTab.ReturnValueNumber( theField, rec )
if ( not ( theValue.IsNull ) ) then
if ( theMinimum = nil ) then
theMinimum = theValue
theMaximum = theValue
else
theMinimum = theMinimum min theValue
theMaximum = theMaximum max theValue
end
theSum = theValue + theSum
theCount = theCount + 1
end
end
theMean = theSum / theCount
theSumSqDev = 0
theSqDev = ( theValue - theMean ) * ( theValue - theMean )
theSumSqDev = theSqDev + theSumSqDev
end
end
if (theCount > 1) then
theVariance = theSumsqdev / (theCount - 1)
theStdDev = theVariance.Sqrt
else
theVariance = 0
theStdDev = 0
end
REC = RESULTVTAB.ADDRECORD
RESULTVTAB.SETVALUE(F1,REC,THEFIELD.GETNAME)
RESULTVTAB.SETVALUE(F2,REC,THESUM)
RESULTVTAB.SETVALUE(F3,REC,THECOUNT)
RESULTVTAB.SETVALUE(F4,REC,THEMEAN)
RESULTVTAB.SETVALUE(F5,REC,THEMAXIMUM)
RESULTVTAB.SETVALUE(F6,REC,THEMINIMUM)
RESULTVTAB.SETVALUE(F7,REC,(THEMAXIMUM - THEMINIMUM))
RESULTVTAB.SETVALUE(F8,REC,THEVARIANCE)
RESULTVTAB.SETVALUE(F9,REC,THESTDDEV)
end
end
RESULTTABLE.SETNAME(RESULTFILE.GETBASENAME)
RESULTTABLE.GETWIN.OPEN
Article ID:000004024
Get help from ArcGIS experts
Download the Esri Support App
