HOW TO
Display hyperlinks in pop-ups based on conditions using Arcade expressions in Portal for ArcGIS and ArcGIS Online Map Viewer Classic
First Published: November 16, 2022
Last Published: November 16, 2022
Summary
In Portal for ArcGIS and ArcGIS Online Map Viewer Classic, Arcade expressions can be used to apply conditional formatting in the pop-up to hide or display specific text or hyperlinks to external web pages pertaining to the field value. This article provides an example and instructions using Arcade expressions to display hyperlinks based on conditions in pop-ups of Map Viewer Classic.
Procedure
  1. Open the map in Map Viewer Classic. Click Details, and click Content.
  2. Click More Options The More Option icon next to the layer next to the layer, and click Configure Pop-up.
  3. Scroll down to the Attribute Expressions section in the Configure Pop-up pane, and click ADD. For this workflow, two Arcade expressions are required.
  4. In the editor window, specify a name for the new expression.
  5. In the Expression dialog box, insert the following Arcade expression to define the text displayed if the condition is met and vice-versa in the Expression section:
return iif($feature.<fieldName> == <fieldValue>, '<fieldValue1>', '<fieldValue2>')
The code below is an example of the full working script.
return iif($feature["LEVEL_NO"] == 6, 'College Application Available', 'College Application Not Available')
  1. Click Test to view a preview of the expression result. If the required result is achieved, click OK.
Specifying the Arcade expression in the Map Viewer Arcade expression editor window
  1. Click ADD to open the Arcade expression editor window to specify the second Arcade expression.
  2. In the editor window, specify a name for the new expression.
  3. In the Expression dialog box, insert the following Arcade expression to configure the display of the link based on one of the two values, 'none' (hide) or 'inline' (show) in the Expression section:
return iif($feature.<fieldName> == <fieldValue>, 'inline', 'none')
return iif($feature["LEVEL_NO"] == 6, 'inline', 'none')
  1. Under the Pop-up Contents section in the Configure Pop-up pane, for Display, click A custom attribute display from the drop-down menu.
Changing the pop-up display option
  1. Click CONFIGURE to open the Custom Attribute Display dialog box.
Selecting Configure to edit the pop-up further in the Configure Pop-up pane
  1. Click the View HTML Source button to switch the view to HTML Source.
  2. In the Custom Attribute Display dialog box, insert the following HTML script, and click OK.
{expression/expr0} <a href="<webpageURL>" style="display:{expression/expr1}" target="_blank" rel="nofollow">(<b><URLDisplayText></b>)</a>
{expression/expr0} <a href="https://portlandbiblecollege.org/admissions/apply-now/" style="display:{expression/expr1}" target="_blank" rel="nofollow">(<b>Apply Now</b>)</a>
Specifying the HTML script in the Custom Attribute Display dialog box
  1. Click OK in the Configure Pop-up pane to apply the pop-up configuration.
The Configure Pop-up pane in Map Viewer Classic
The image below shows the configured pop-up whereby the pop-up displays the hyperlink when the point selected is a college.
The configured pop-up window displaying the hyperlink when the point feature is a college
The image below shows the configured pop-up whereby the pop-up does not display the hyperlink when the point selected is not a college.
The configured pop-up window with the hidden hyperlink when the point feature is not a college
Article ID: 000028533
Software:
  • ArcGIS Online
  • Portal for ArcGIS
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
