HOW TO
Display filtered data based on queries using the Feature Info widget in ArcGIS Experience Builder
First Published: May 15, 2024
Last Published: August 5, 2026
Summary
In ArcGIS Experience Builder, data can be filtered based on the queries defined in the Query widget and displayed in a frame outside a map using the Feature Info widget. This is useful for displaying complex queries against the data layers clearly and appropriately. For instance, users can execute a spatial query to identify all features within a specific area and use the Feature Info widget to explore attributes or other details of those features.
This article details the workflow for adding queries to a Feature Info widget. It is based on utilizing an existing Query widget configured to spatially filter features by intersecting them with the geometries drawn on the Map widget within Experience Builder.
Procedure
  1. In Experience Builder, on the Insert widget panel, search for the Feature Info widget, drag and drop it to the canvas.
  2. Click the Feature Info widget. On the right panel, on the Content tab, under Source, click Select data > Add data.
  3. In the Content configuration pane, under Data, click Select data.
  4. In the Select data pane, under Type, click Outputs.
  5. Under Outputs, expand Query and select the query created in the existing Query widget.
Query added to the Feature Info widget
  1. Click Save The Save icon to save the configurations.
The Feature Info widget below displays feature details based on the spatial filter query configuration in Experience Builder.
The Feature Info widget displays feature details based on a query
Article ID: 000032467
Software:
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
