HOW TO
Display coordinates in latitude-longitude order in ArcGIS Experience Builder
First Published: July 21, 2026
Last Published: July 21, 2026
Summary
In ArcGIS Experience Builder, coordinate results returned by some widgets can be displayed in specific formats such as latitude-longitude (Y, X), where latitude values are displayed before longitude values in decimal degrees (DD). This provides a consistent method for representing spatial information on a map and enables precise location referencing for mapping and spatial analysis.
This article provides the options to display coordinates in latitude-longitude order in ArcGIS Experience Builder.
Procedure
Configure the Coordinates widget
  1. Create a web experience and add a Map widget in ArcGIS Experience Builder. Refer to ArcGIS Experience Builder: Create your first web experience for instructions.
  2. In the Insert widget panel, under Map centric, drag and drop the Coordinates widget onto the canvas.
  3. In the configuration panel, configure the following settings:
  1. For Select a Map widget, click the drop-down arrow and select the map under Current page.
  2. For Output coordinate system, ensure the map’s coordinate system is used. Optionally, click New coordinate system to add and configure the preferred coordinate system.
  3. Under Display options, for Display order, select Latitude/Longitude (Y, X).
The Display options section
  1. Save, preview, and publish the experience.
The experience below shows the coordinates in latitude-longitude order in the Coordinates widget.
The coordinates displayed in the Coordinates widget
Configure the Coordinate Conversion widget
  2. In the Insert widget panel, under Map centric, drag and drop the Coordinate Conversion widget onto the canvas.
  3. In the configuration panel, for Select a Map widget, click the drop-down arrow and select the map under Current page.
  4. For Address settings, ensure the default geocoding service is used. Optionally, click Select utility to add and configure the preferred geocoding service.
  5. Expand Output settings and click Add new labels to create a new output notation.
  6. In the Add Conversion dialog box, set the following configurations:
  1. For Default coordinate, select Long-Lat from the drop-down list.
  2. For Label, specify the label name for the output notation. In this example, it is Latitude-Longitude.
  3. For Format, highlight the content, remove the existing format, and type Y°‎, X° in the text box.
Optionally, select the Add new conversion at the top of the list option to display the new output notation at the top of the widget’s output section.
  1. Click OK.
The Add Conversion dialog box
Optionally, deselect unused output coordinate formats under Output settings to prevent them from being displayed in the widget.
The experience below shows the coordinates in latitude-longitude order in the Coordinate Conversion widget.
The coordinates displayed in the Coordinate Conversion widget
Configure the Search widget
  2. In the Insert widget panel, under Data centric, drag and drop the Search widget onto the canvas.
  3. In the configuration panel, select Interact with a Map widget. Click the drop-down arrow and select the map under Current page.
  4. Toggle Customize search sources on and click ArcGIS World Geocoding Service. Optionally, click New search source to add and configure a locator source.
  5. In the Set locator source panel, under Search options, for Display fields, select X and Y from the drop-down list.
The X and Y fields from the drop-down list
Optionally, deselect Default Address from the Display fields drop-down list.
  1. Drag the Y field to be above the X field.
The Y and X fields are reordered in the list
The experience below shows the coordinates in latitude-longitude order in the Search widget.
The coordinates displayed in the Search widget
Article ID: 000042426
Software:
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
