HOW TO
ArcGIS determines the default rendering options available for a raster catalog based on the properties of the rasters referenced through the catalog. Certain situations may require the data in the raster catalog to be displayed with a different rendering option. Instructions provided describe how to display a raster catalog using a non-default renderer.
If a renderer that is not listed on the left portion of the window is desired, remove all renderers by clicking on the remove button. Then use the add button to select and add the new renderers. These renderers can then be applied to the catalog.
Article ID:000010231
Get help from ArcGIS experts
Download the Esri Support App
