HOW TO
Display 3D point depth data in ArcGIS Pro
Last Published: November 10, 2022
Summary
3D point depth data can be used to display the location of underground points. In this article, depth data with negative z-values are used to construct underground 3D points. Viewing the data in 3D points highlights the elevation and depth so a more realistic representation is displayed. This article highlights the workflow to display 3D point depth data in ArcGIS Pro.
Procedure
Note: Features must be z-enabled to represent elevations or heights in three dimensions. In this workflow, a feature with a negative z-value field is used to display depth data.
  1. In ArcGIS Pro, on the ribbon, click Insert.
  2. Under the Insert tab, click the drop-down arrow next to New Map.
  3. Select New Global Scene to create a new 3D scene.
Open a new global mao
  1. Add the desired feature to the Scene map. In this example, Test_Z is used.
  2. Right-click the layer and select Properties.
Add a feature to the map
  1. In the Layer Properties window, select Elevation.
  2. For the Features are, click the drop-down list and select At an absolute height.
Select an elevation feature
  1. Under Additional features elevation using, check the A field option.
  2. Select a Z-value field for A field.
  3. Select an appropriate value for Vertical Exaggeration. Click OK.
Select a Vertical Exaggeration
  1. In the Contents pane, under Drawing Order, expand Scene > Elevation Surfaces if necessary, and click Ground.
Click Ground
  1. On the ribbon, click Elevation Surface Layer and check the Navigate Underground check box.
Check the Navigate Underground box
Article ID: 000028559
Software:
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
