HOW TO
Disperse geocoded point features within a polygon using ArcPy in ArcGIS Pro
Last Published: November 22, 2023
Summary
In ArcGIS Pro, dispersing points is a process to distribute a set of point features across a specific area. This is useful for a variety of reasons, such as to improve the visual representation of data from closely clustered points and for spatial modeling or simulation to create more realistic representations of features are distributed in the real world.
This article describes the workflow to disperse geocoded point features within a polygon using ArcPy in ArcGIS Pro.
Procedure
This workflow requires the full script to run in the ArcGIS Pro Python window.
  1. In ArcGIS Pro, open the map containing the point and polygon feature classes.
  2. Open the Python window. Refer to ArcGIS Pro: Python window for more information.
  3. Run the following script:
    1. Import the necessary modules.
import arcpy
import random
  1. In the main() function definition, set up the necessary environment and file paths. Replace '<filePath1>' and '<filePath2>' with the paths of the point and polygon feature classes. Retrieve the shape of the polygon using the SearchCursor() function.
def main():
    fcPoints = r"<filePath1>"
    fcPolygon = r"<filePath2>"
    arcpy.env.overwriteOutput = True
    with arcpy.da.SearchCursor(fcPolygon, ("SHAPE@")) as cursor:
        for row in cursor:
            polygon = row[0]
            disperse_points(fcPoints, polygon)
        del row
    print ("ready...")
  1. Create a point geometry at coordinates representing the point and check if it is within the polygon.
def point_in_poly(poly, x, y):
    pg = arcpy.PointGeometry(arcpy.Point(x, y), poly.spatialReference)
    return poly.contains(pg)
  1. Disperse the points within the provided polygon. If a point originally falls inside the polygon, it is moved to a new random location within the polygon. If a point originally does not fall inside the polygon, it remains in its original location.
def disperse_points(in_points, polygon):
    lenx = polygon.extent.width
    leny = polygon.extent.height
    with arcpy.da.UpdateCursor(in_points, "SHAPE@XY") as points:
        for p in points:
            if point_in_poly(polygon, p[0][0], p[0][1]):
                x = (random.random() * lenx) + polygon.extent.XMin
                y = (random.random() * leny) + polygon.extent.YMin
                inside = point_in_poly(polygon, x, y)
                while not inside:
                points.updateRow([(x, y)])
            else:
                pass
  1. Run a logic to call the main function created in Step 3b.
if __name__ == '__main__':
    main()‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
The code block below demonstrates the full working script.
import arcpy
import random
def main():
    fcPoints = r"C:\Users\Documents\ArcGIS\Projects\MyProject22\MyProject22.gdb\point"
    fcPolygon = r"C:\Users\Documents\ArcGIS\Projects\MyProject22\MyProject22.gdb\TestPolygons"
        for row in cursor:
            polygon = row[0]
        del row
    print ("ready...")
        for p in points:
                while not inside:
            else:
                pass
    main()
  1. Click Refresh The Refresh button to reflect the changes on the map.
The points are dispersed in the polygon as demonstrated in the image below.
Article ID: 000031489
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
