HOW TO
Disable timeout warnings for expiring licenses
First Published: May 5, 2016
Last Published: April 6, 2021
Summary
When licenses are near expiring or have already expired, warning messages are displayed when starting ArcGIS applications. The instructions in this article describe how to disable the warning messages.
Procedure
The workarounds in this article must be performed by an Administrator, or with a Windows account with full administrative privileges.
Disable the timeout warning via ArcGIS Administrator
  1. Launch ArcGIS Administrator.
  2. Select Advanced... to open the Advanced Configuration window.
The 'Advanced...' button in ArcGIS Administrator to open the Advanced Configuration window.
  1. Under License Expiration, uncheck the Show license expiration warning messages checkbox. Click Save.
Unchecking the 'Show license expiration warning messages' checkbox in the License Expiration section of the Advanced Configuration window.
  1. Click Apply > OK.
Disable the timeout warning via the Advanced ArcMap Settings utility
The following workaround can only be performed by an Administrator, or a Windows account with full administrative privileges. Under certain network configurations, the Advanced ArcMap Settings utility may not be visible to non-administrative accounts.
  1. Depending on the installed version of ArcGIS Desktop, navigate to the installation directory.
ArcGIS Desktop 10.x: C:\Program Files (x86)\ArcGIS\Desktop10.x\Utilities\
  1. Launch the AdvancedArcMapSettings.exe file.
  2. Select the Miscellaneous tab.
  3. Under License timeout warning, uncheck the Starting 15 days prior to an evaluation or software licensing timeout, show a warning message when opening applications checkbox.
  4. Click Apply > Close.
Launch AdvancedArcMapSettings.exe, and select the Miscellaneous tab. Uncheck the checkbox under 'License timeout warning'. Click Apply, and Close.
Warning:
Disabling warning messages does not prevent a license from expiring. Contact Esri Customer Service to acquire a new license if needed.
Article ID: 000003042
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
