HOW TO
Disable the Save Username and Password check box in the New Spatial Database Connection dialog box
Summary
Instructions provided describe how to disable the Save Username and Password check box on the New Spatial Database Connection dialog box so that these settings cannot be persisted in the sde connection files. This prevents a user from connecting to data they should not have access to, even if they are provided with an sde connection file.
Procedure
Whether the Save Username and Password check box is enabled through the use of a registry setting can be controlled.
  1. Create a key called "DisableUsernamePasswordCheckBox" of type DWORD, under the following:
    ArcGIS 9.3.1
    HKEY_CURRENT_USER\Software\ESRI\Geodatabase\Settings
    ArcGIS 10.0 and later
    HKEY_CURRENT_USER\Software\ESRI\Desktop###\Geodatabase\Settings
    Where Desktop### is the release of Desktop being used. For example, 10.0 is Desktop10.0 and 10.1 is Desktop10.1
    If the 'Geodatabase\Settings' keys are not present in the registry path, create them.
  2. Set the value of the registry setting to 1 to disable the Save Username and Password check box. A value of 0 or any other value results in the default behavior; the check box is enabled.
    Once set, the check box is disabled.
    [O-Image]
Article ID:000010618
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
