HOW TO
Disable the App State pop-up in ArcGIS Web AppBuilder
First Published: July 13, 2020
Last Published: July 27, 2023
Summary
When viewing or after refreshing the ArcGIS Web AppBuilder app, the pop-up message, 'Click to restore the map extent and layers visibility where you left off' is displayed at the bottom-right corner by default. In some cases, it is best to disable the pop-up if it is not required.
Image of the App State pop-up
This article provides steps to disable the App State pop-up in ArcGIS Web AppBuilder.
Procedure
When the ArcGIS Web AppBuilder app is created, the App state check box is turned on by default. Refer to ArcGIS Web AppBuilder: App state for more information.
  1. Log in to ArcGIS Online or Portal for ArcGIS.
  2. Navigate to Content > My Content.
  3. Browse to the desired Web AppBuilder for ArcGIS app, click More Options Image of the More Options button, and click Edit Application.
Image of the My Content window
  1. On the Attribute tab, under App state, uncheck the Keeps map extent and layers visibility while leaving the app. check box.
Image of the Attribute tab
  1. Click Save to save the app.
The App State pop-up is not displayed when viewing or after refreshing the ArcGIS Web AppBuilder app.
Image of ArcGIS Web AppBuilder
Article ID: 000023449
Software:
  • ArcGIS Web AppBuilder
  • ArcGIS Online
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
