HOW TO
Determine the Working Directory of a damaged ArcView project
Summary
Knowing the location of a project's Working Directory can be helpful in troubleshooting a project that does not open.
Procedure
  1. Open the damaged .apr file in a text editor, such as Notepad or WordPad. You may need to set Files of type to All Files in the Open dialog box to see .apr files.
  2. Search the document for the string WorkDir. There should be a number associated with the WorkDir, write this number down. For example:
    WorkDir:  848
  3. Starting at the top of the file, search for the number found above. For example, 848 finds something like the following:
    (FN.848
  4. A few lines down there should be the path to the project's Working Directory. For example:
     Path:  "c:/temp"
Article ID:000004675
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
