HOW TO
Determine the last login in ArcGIS Enterprise portal and ArcGIS Online using ArcGIS API for Python
First Published: January 16, 2020
Last Published: July 22, 2026
Summary
The last login dates are helpful in determining the list of active users in ArcGIS Enterprise portal and ArcGIS Online. Administrators have the required privileges to view audit logs and remove non-active users to free up licenses for new users. The last login dates can be determined using ArcGIS API for Python.
Procedure
Complete the steps below to determine the last login date in ArcGIS Enterprise portal and ArcGIS Online using ArcGIS API for Python.
  1. Import the necessary module, including the time module.
import arcgis
import time
from arcgis.gis import GIS
    1. Make an administrator connection to ArcGIS Enterprise portal or ArcGIS Online.
    gis = GIS("https://domain.esri.com/portal", username="user1", password="pass1", verify_cert=False)
    print("connected")
    ArcGIS Online
    gis = GIS("https://arcgis.com", username="username", password="password")
    print("connected")
    1. Search for the list of users in ArcGIS Enterprise portal or ArcGIS Online. Set the maximum number of users if needed.
    a_users = gis.users.search(query='', max_users=200)
    a_users
    1. Loop through the list of available users, and print the login record for ArcGIS Enterprise portal or ArcGIS Online.
    for a_user in a_users:
        if a_user. lastLogin != -1:
            last_accessed = time.localtime(a_user. lastLogin/1000)
            print(str(a_user. fullName) + " was last active on: {}/{}/{}\n".format(last_accessed[0], last_accessed[1], last_accessed[2]))
        else:
          print(str(a_user. fullName) + " has never logged in.\n")
    The following shows the full script:
    import arcgis
    import time
    #For Portal for ArcGIS
    #For ArcGIS Online
    print("connected")
    a_users
        else:
    The image below shows the result of the above script.
    Result of the Python script.
    Article ID: 000022604
    Software:
    • ArcGIS Online
    • Portal for ArcGIS
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
