HOW TO
Determine the intersecting area between a parcel fabric and a non-parcel fabric polygon layer
Summary
The intersecting area between a parcel fabric and a non-parcel fabric polygon layer can be determined in ArcMap. This is useful in determining the total area of properties affected by natural disaster or human-caused damage, such as a flooding event, crop lands affected by toxic waste, or a neighborhood impacted by a forest fire.
For example, the image below shows a neighborhood in Naperville, Illinois, which is affected by a flooding event. The parcel fabric represents the properties and the non-parcel fabric polygon layer represents the flood zone. This article describes how to calculate the total area of properties affected by the flooding.
The parcel fabric properties and the non-parcel fabric flood zone.
Procedure
The following workflow describes how to determine the intersecting area between a parcel fabric and a non-parcel fabric polygon layer:
  1. In ArcMap, a parcel fabric is shown as a group layer with several feature layers within the parcel fabric. Navigate to Table Of Contents, and export the Tax Parcels layer of a parcel fabric to a feature class. For more information on exporting layers, refer to ArcMap: Creating a new feature class by saving the contents of a map layer in ArcMap.
This is Table Of Contents.
  1. In the Export Data dialog box, navigate to the Output feature class field, and click the Browse button. Specify the Save as type field as a feature class and locate the desired geodatabase.
This is the Export Data dialog box.
A polygon feature class is created from the Tax Parcels layer in the parcel fabric.
This is the polygon feature class created from the Tax Parcels layer.
The recently-created polygon (tax parcels) layer is located at the top of Table Of Contents. For easier data visualization, turn off the fabric group layer and position the recently-created polygon (tax parcels) layer below the non-parcel fabric polygon (flood zone) layer.
  1. Navigate to Geoprocessing > Intersect.
  2. In the Intersect dialog, set the Input Features to the polygon feature class created from the tax parcels layer in Step 2, and the polygon layer representing the flood zone. For more information on the Intersect tool, refer to ArcMap: Intersect.
This is the Intersect dialog box.
  1. Click OK.
    An intersection of the two feature classes is generated as a new feature class, added as a layer in Table Of Contents, and symbolized in a different color in the map view as in the image below.
This is the intersect layer created.
  1. In Table Of Contents, right-click the intersecting layer generated. Click Open Attribute Table.
  2. In the attribute table, right-click the Shape_Area field header, and click Statistics. The Sum field shows that the intersecting area of properties affected by the flood zone is 24,592,824 square feet. For more information, refer to ArcMap: Viewing statistics for a table.
This is the Statistics window.
The output unit of the Statistics calculation depends on the layer unit, which is determined by right-clicking the specified layer from Table Of Contents, and clicking Properties. In the Layer Properties dialog box, click the Source tab and scroll down to the Linear Unit field. (See the image below.) The Linear Unit field specifies the layer unit, while the area is expressed in a square linear unit.
This is the Layer Properties window.
Article ID: 000018376
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
