HOW TO
Determine the corner coordinates of a map frame in an ArcGIS Pro layout
First Published: March 20, 2024
Last Published: March 16, 2026
Summary
Coordinates are essential in mapping accurate navigation and for efficient data sharing, especially the map's corners: upper-left and right, and lower-left and right. Determining the latitude and longitude of these corners is useful in georeferencing maps and aligning them to real-world coordinates. In ArcGIS Pro, the coordinates of a location in a layout's map frame can be determined using grids. However, as demonstrated below, when the corner of the map is positioned between one of the grids, the map's corner frame coordinates are not displayed.
A map frame in a layout with a grid displaying the coordinates
This article describes the workflow to determine the corner coordinates of a map frame in an ArcGIS Pro layout.
Procedure
  1. Open the ArcGIS Pro project.
  2. Click the Layout tab to activate the layout view. The tab color turns blue.
  3. On the ribbon, click the Insert tab, and click New Dynamic Text in the Graphics and Text group.
  4. In the gallery, scroll down to the Map Frame - Coordinates group and refer to the Upper Left, Upper Right, Lower Left, and Lower Right dynamic text tags for the corner coordinates of the layout. In this example, the upper-left coordinate of the layout (Upper Left) is 100°3'41"E 5°54'36"N.
The gallery of the dynamic text tags
Add the coordinate dynamic text to the layout view. Refer to ArcGIS Pro: Add dynamic text to a layout for instructions.
The coordinate dynamic text below the map frame in the layout view.
Article ID: 000032191
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
