HOW TO
Determine the character index of a glyph in a TrueType font.
Summary
Instructions provided describe how to determine the CharacterIndex value of TrueType fonts.
Procedure
When working with point features and want to symbolize them with TrueType fonts -- for example, the ESRI fonts that come with MapObjects -- you specify the CharacterIndex property to designate the character code in the Font associated with the Symbol. You can determine the CharacterIndex values for the symbols through trial and error or, if you have Microsoft Word, you can get the number that matches the symbol you want easily. Here's how to do it.
  1. Under Microsoft Word's Format menu, select the Style drop-down menu choice and set styles to Normal.
  2. Under the Format menu, set the Font to the name of a TrueType font.
  3. In the Insert menu, select the Symbol. You'll see the characters of the font in the Symbols tab.
  4. Using your mouse, select one of the symbols. You'll see the CharacterIndex value in Microsoft Word's Status bar.
Article ID:000004293
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
