HOW TO
Instructions provided describe how to determine if an instance of SQL Server Express is enabled to be used as a database server.To identify if a SQL Server Express instance has been enabled to store geodatabases, check the Microsoft SQL Server services hive in the Windows Registry.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\MSSQL$<SQL Server Express instance name>
By default, SQL Server Express instances are named sqlexpress, but this value may be different if another name was used when SQL Server Express was installed.
Article ID:000011592
Get help from ArcGIS experts
Download the Esri Support App
