HOW TO
Determine if a geodatabase contains a relationship class using ArcPy
Last Published: November 26, 2020
Summary
Relationship classes can be created on a geodatabase with the Standard or Advanced ArcGIS Desktop license. Relationship classes manage the associations between objects in a feature class and a table. As there can be multiple geodatabases within a workspace, manually checking if a relationship class exists in a geodatabase can be tedious. This article provides an alternative method to determine if there is a relationship class in all the geodatabases within a workspace using ArcPy.
Procedure
  1. Import the necessary modules.
import arcpy
from arcpy import env
  1. Specify the desired workspace.
workspace = env.workspace = r"<workspace_location>"
  1. Create a function to find the relationship classes in the specified workspace.
def detectRelationship():
     rc_list = [c.name for c in arcpy.Describe(workspace).children if c.datatype == "RelationshipClass"]
     rc_list
     # List the names, origin, and destination of the relationship class
     for rc in rc_list:
         rc_path = workspace + "\\" + rc
         des_rc = arcpy.Describe(rc_path)
         origin = des_rc.originClassNames
         destination = des_rc.destinationClassNames
         print ("Relationship Class: %s \n Origin: %s \n Desintation: %s" %(rc, origin, destination))
  1. Call the function, and return the results if a relationship class exists.
The following code block and image shows shows the full script and the result:
import arcpy
workspace = env.workspace = r"C:\Users\USER\Desktop\Test_case"
     rc_list
     for rc in rc_list:
Image of a sample result
Article ID: 000023985
Software:
  • ArcMap
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
