HOW TO
Detect orphaned states and lineages in Oracle
Summary
**Internal Publish Only! This article may contain information that is not intended for external circulation.**Instructions provided describe how to use SQL queries to check for orphaned states or lineages in a SQL server as the target state may not be in the states table or the lineage referencing the state may be missing.
Procedure
1. Start SQLPLUS and connect as the 'sde' user.
2. Run the following queries:
a) Check for Incomplete or missing lineages:
select state_id from sde.states ST where not exists
(select * from sde.state_lineages SL
where ST.lineage_name = SL.lineage_name and SL.lineage_id = 0);
b) Check for Invalid parent state ids:
select state_id from sde.states where parent_state_id not in
(select state_id from sde.states)
order by state_id;
c) Check for States with no lineages:
select distinct state_id from sde.states where lineage_name not in
(select lineage_name from sde.state_lineages)
order by state_id;
select distinct state_id from sde.states where state_id not in
(select lineage_id from sde.state_lineages)
order by state_id;
d)Check for edits referencing states with no parent state:
select state_id from sde.MVTABLES_MODIFIED
where state_id in (select state_id from sde.states where parent_state_id not in
(select state_id from sde.states));
If the above queries return 'no records', the states and lineages tables are not the source of the problem.
Article ID:000008462
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
