HOW TO
Instructions provide a code sample which deletes selected features.
Code in the Project's ThisDocument code module will only run in the current map document. If you want to store the code in all your map documents open the Normal.mxt ThisDocument code module instead.
Code:
Option Explicit
Public Sub Main()
Dim pDoc As IMxDocument
Dim pLayer As IFeatureLayer
Dim mySet As ISet
Dim pFeature As IFeature
Dim pEnumFeature As IEnumFeature
Dim pEditor As IEditor
Dim pUID As New UID
Set pDoc = Application.Document
Set pEnumFeature = pDoc.ActiveView.Selection
pEnumFeature.Reset
Set pFeature = pEnumFeature.Next
pUID = "esricore.editor"
Set pEditor = Application.FindExtensionByCLSID(pUID)
'Make certain the layer is selected in the TOC
Set pLayer = pDoc.SelectedLayer
'Check to make certain that there is an edit session started
If pEditor.EditState = esriStateNotEditing Then
MsgBox "Cannot Edit outside of an edit session"
End If
'Call the DeleteSelectedFeatures sub procedure
'and pass in the EnumFeature object.
DeleteSelectedFeatures pEnumFeature
pDoc.ActiveView.Refresh
End Sub
Private Sub DeleteSelectedFeatures(pEnumFeature As IEnumFeature)
Dim mySet As esriCore.ISet
Set mySet = New esriCore.Set
Dim pFeatureEdit As IFeatureEdit
pEnumFeature.Reset
'Takes features and writes them out to an ISet object
Do Until pFeature Is Nothing
Set pFeatureEdit = pFeature
mySet.Add pFeature
Loop
'Calls the deleteset method from IFeatureEdit
'to delete the selected set of records
pFeatureEdit.DeleteSet mySet
End Sub
Article ID:000006280
Get help from ArcGIS experts
Download the Esri Support App
