HOW TO
Geoprocessing tools add metadata about its execution in a geodatabase. The metadata includes the tool name, its location, and the parameters used when geoprocessing logging is enabled. GIS administrators and managers sometimes need to delete the geoprocessing history from a feature class or workspace metadata.
The following script describes how to achieve this goal using a Python script and workflow of how to remove geoprocessing history from an enterprise geodatabase workspace.
Remove geoprocessing history from feature classes
The instructions provided below describe how to achieve this goal using a Python script. The following script automates this process for all feature classes in a geodatabase, including feature classes stored in a feature dataset.
Note: Perform the procedure in the 32-bit version of Python.
Run the included Python script after updating the variables:
import arcpy import os, string ''' Update the following five variables before running the script.''' version = "10.5" myWorkspace = r"C:\XML_out\dbinstance_testgdb.sde" gp_history_xslt = r"C:\Program Files (x86)\ArcGIS\Desktop{}\Metadata\Stylesheets\gpTools\remove geoprocessing history.xslt".format(version) output_dir = r"C:\XML_out" db_type = "SQL" #Set this to either "SQL" or "Oracle" if your db has spatial views. If not you may set it to "". def RemoveHistory(myWorkspace, gp_history_xslt, output_dir): ##Removes GP History for feature dataset stored feature classes, and feature classes in the File Geodatabase. arcpy.env.workspace = myWorkspace for fds in arcpy.ListDatasets('','feature') + ['']: for fc in arcpy.ListFeatureClasses('','',fds): data_path = os.path.join(myWorkspace, fds, fc) if isNotSpatialView(myWorkspace, fc): removeAll(data_path, fc, gp_history_xslt, output_dir) def isNotSpatialView(myWorkspace, fc): ##Determines if the item is a spatial view and if so returns True to listFcsInGDB() if db_type <> "": desc = arcpy.Describe(fc) fcName = desc.name #Connect to the GDB egdb_conn = arcpy.ArcSDESQLExecute(myWorkspace) #Execute SQL against the view table for the specified RDBMS if db_type == "SQL": db, schema, tableName = fcName.split(".") sql = r"IF EXISTS(select * FROM sys.views where name = '{0}') SELECT 1 ELSE SELECT 0".format(tableName) elif db_type == "Oracle": schema, tableName = fcName.split(".") sql = r"SELECT count(*) from dual where exists (select * from user_views where view_name = '{0}')".format(tableName) egdb_return = egdb_conn.execute(sql) if egdb_return == 0: return True else: return False else: return True else: return True def removeAll(data_path, feature, gp_history_xslt, output_dir): ##Remove all GP History metadata from a feature class. arcpy.ClearWorkspaceCache_management() name_xml = os.path.join(output_dir, str(feature)) + ".xml" arcpy.XSLTransform_conversion(data_path, gp_history_xslt, name_xml) print "Completed xml coversion on {0}".format(feature) arcpy.MetadataImporter_conversion(name_xml, data_path) print "Imported XML on {0}".format(feature) def makeDirectory(output_dir): ##Creates directory to store the xml tables of converted metadata. If the ##directory already exists, the files will be created there. if not arcpy.Exists(output_dir): os.mkdir(output_dir) if __name__ == "__main__": makeDirectory(output_dir) RemoveHistory(myWorkspace, gp_history_xslt, output_dir) print "Done Done"
Remove geoprocessing history from an enterprise geodatabase workspace
C:\Program Files (x86)\ArcGIS\Desktop10.5\Metadata\Stylesheets\gpTools\remove geoprocessing history.xslt
Article ID: 000011751
Get help from ArcGIS experts
Download the Esri Support App
