HOW TO
Delete annotations in ArcGIS Business Analyst
Last Published: October 14, 2022
Summary
Annotations are added to a map in ArcGIS Business Analyst to highlight specific areas and provide additional information. Sometimes, a specific annotation needs to be deleted individually for editing purposes.
This article describes how to delete annotations in ArcGIS Business Analyst Web App.
Procedure
For Text and Image annotations
  1. Log in to ArcGIS Business Analyst Web App and open the project.
  2. Click Add Annotation from the map tools. The Add Annotation window opens.
  3. Use one of the following steps to remove either Text or Image annotations.
  • Click the Text annotation in the map with the Add Annotation window open and click the delete The delete button button in the text box. The text is removed from the map.
The Add Annotation window and the delete button for the Text annotation
  • Click the Image annotation in the map and click the delete button in the Select imported image option. Click OK in the Delete Image dialogue box. The image is removed from the map.
The Add Annotation window and the delete button for the Image annotation
For Shape and Draw annotations
By default, there is no option to delete the Shape and Draw annotations in ArcGIS Business Analyst Web App. This procedure describes an alternative solution using the transparency slider to completely hide the annotations. The annotation can still be selected on the map.
  3. Click the Shape annotation on the map with the Add Annotation window open and navigate to the Fill and Border settings, respectively.
  4. Set the Transparency option to 100%. The shape is no longer visible on the map.
The Add Annotation window’s Shape tab and the Transparency options
  1. Repeat Steps 3 and 4 to conceal the Draw annotation.
The Add Annotation window’s Draw tab and the Transparency options
Article ID: 000028423
Software:
  • ArcGIS Business Analyst Web App
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
