HOW TO
ISnapEnvironment can reference the properties of SnapAgent FeatureSnap objects.
Code:
Dim pUID As UID
Dim pEditor As IEditor
Set pUID = New UID
pUID = "esricore.Editor"
Set pEditor = Application.FindExtensionByCLSID(pUID)
pEditor.StartEditing pWorkspace
This code example assumes the pWorkspace variable has been defined as an IWorkspace and has been set to a valid workspace.
Code:
Dim pSnapEnvironment As ISnapEnvironment
Dim pFeatureSnapagent As IFeatureSnapAgent
Set pSnapEnvironment = pEditor
Set pFeatureSnapAgent = New FeatureSnap
Set pFeatureSnapAgent.FeatureClass = pFeatureClass
pFeatureSnapAgent.HitType = esriGeometryPartBoundary
pSnapEnvironment.ClearSnapAgents
pSnapEnvironment.AddSnapAgent pFeatureSnapagent
pSnapEnvironment.SnapToleranceUnits = esriSnapTolerancePixels
pSnapEnvironment.SnapTolerance = 5
This code example assumes the pFeatureClass variable has been defined as an IFeatureClass and has been set to a feature class with edges (such as polygons).
Code:
Dim pPoint1 As IPoint
Dim pPoint2 As IPoint
Set pPoint1 = New Point
Set pPoint2 = New Point
pPoint1.X = 413188.31
pPoint1.Y = 1124061.78
pPoint2.X = 438944.57
pPoint2.Y = 1123086.17
pSnapEnvironment.SnapPoint pPoint1
pSnapEnvironment.SnapPoint pPoint2
Code:
Dim pSketchOperation As ISketchOperation
Dim pEditSketch As IEditSketch
pEditor.StartOperation
Set pSketchOperation = New SketchOperation
pSketchOperation.Start pEditor
Set pEditSketch = pEditor
pEditSketch.AddPoint pPoint1, True
pEditSketch.AddPoint pPoint2, True
pEditSketch.FinishSketch
pEnvelope.Expand 1.2, 1.2, True
pSketchOperation.Finish pEnvelope
This code assumes the pEnvelope was defined as IEnvelope and has the extent of the feature currently selected and being edited.
Article ID:000002754
Get help from ArcGIS experts
Download the Esri Support App
