HOW TO
Define a field as unique using ArcGIS API for Python
First Published: July 3, 2024
Last Published: July 3, 2024
Summary
Unique values symbolize qualitative categories of values and can be based on one or more attribute fields in the dataset. When data are published to ArcGIS Online or Portal for ArcGIS, unique constraints can be added to a field to ensure no duplicate values are stored. This method is useful in identifying unique features, and improves labeling. It also helps stop operations such as appending or updating that add duplicate values into the fields. Constraints can be added by accessing the Data page of the hosted feature layer. It can also be added using ArcGIS API for Python and this article provides the workflow.
Procedure
  1. Import the necessary modules and specify the credentials.
from arcgis.gis import GIS
from arcgis.features import FeatureLayer, Table, FeatureLayerCollection
#For ArcGIS Online
gis = GIS("ORGANIZATION_URL", "username", "password")
#For ArcGIS Notebook
gis = GIS("Home")
#For Portal for ArcGIS
gis = GIS("https://<machine>.<domain>.com/<web_adaptor_name>", "username", "password", verify_cert=False)
  1. Specify the hosted feature layer to be used.
featurel_url = "https://services.domain.com/<xxxxxxxxxxx>/arcgis/rest/services/<feature_layer>/FeatureServer/<sublayer_id>"
fl = FeatureLayer(fl_url, gis)
  1. Add the index and definition to set the unique values in the desired field. Ensure the isUnique parameter is set to True.
definition_to_add = {"indexes":[
        "fields": "<field_name>",
        "isUnique": True,
        "description": "description"
fl.manager.add_to_definition(definition_to_add)
The code block below shows the full working script for Portal for ArcGIS.
gis = GIS("https://machine.esri.com/arcgis", "username123", "password123", verify_cert=False)
featurel_url = "https://services.domain.com/xxxxxxxxxxx/arcgis/rest/services/testUnique/FeatureServer/0"
        "fields": "<field>",
        "isUnique": True,
Article ID: 000032984
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS API for Python
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
