HOW TO
A SAML assertion, which may be referred to as a SAML response, is an XML document that contains information such as
An identity provider (for example, Microsoft Entra) or a service provider (for example, ArcGIS Enterprise) may use the term “claim” when referring to user attributes/properties/roles/etc.
Attempts to automatically create ArcGIS SAML members, or to sign in to ArcGIS using a SAML login, may fail if the attributes included in a SAML response by an identity provider are incorrect.
Details of any error messages generated by the identity provider may be included in the SAML response.
A useful workflow for investigating a SAML authentication failure is therefore to inspect the SAML response.
Note: This workflow will not work if SAML assertions are encrypted. Refer to the following help topic: Configure a SAML-compliant identity provider: Advanced settings
<samlp:Response ID="_d5d0f8a9-e4a8-4460-a13c-02a464330f58" Version="2.0" IssueInstant="2026-07-27T22:47:10.680Z" Destination="https://aws11-5.supportesriau.com.au/portal/sharing/rest/oauth2/saml/signin" InResponseTo="_bSzkMgnvnAUMhJiK"
xmlns:samlp="urn:oasis:names:tc:SAML:2.0:protocol">
<Issuer
xmlns="urn:oasis:names:tc:SAML:2.0:assertion">https://sts.windows.net/e96b131a-a060-4b26-a453-d53d9fb2b181/
</Issuer>
<samlp:Status>
<samlp:StatusCode Value="urn:oasis:names:tc:SAML:2.0:status:Success"/>
</samlp:Status>
<Assertion ID="_722e4683-9660-4aa0-977b-70c9b8c81900" IssueInstant="2026-07-27T22:47:10.672Z" Version="2.0"
<Issuer>https://sts.windows.net/e96b131a-a060-4b26-a453-d53d9fb2b181/</Issuer>
<Signature
xmlns="http://www.w3.org/2000/09/xmldsig#">
<SignedInfo>
<CanonicalizationMethod Algorithm="http://www.w3.org/2001/10/xml-exc-c14n#"/>
<SignatureMethod Algorithm="http://www.w3.org/2001/04/xmldsig-more#rsa-sha256"/>
<Reference URI="#_722e4683-9660-4aa0-977b-70c9b8c81900">
<Transforms>
<Transform Algorithm="http://www.w3.org/2000/09/xmldsig#enveloped-signature"/>
<Transform Algorithm="http://www.w3.org/2001/10/xml-exc-c14n#"/>
</Transforms>
<DigestMethod Algorithm="http://www.w3.org/2001/04/xmlenc#sha256"/>
<DigestValue>Wxe1lthTTE4vS6TzBwgVvKd/YuVM+sFPYRI+t3JMlyI=</DigestValue>
</Reference>
</SignedInfo>
<SignatureValue>MSBa0nkiEPX0PtjewemmMONBrDiRe8Qz2272r/z1NUiShkCC1C/Gco42uGq3eKRSCi6Byr09W6nTxMm+sqfebSBx+CLU8dUmQ8zEERBCajMsjRF3h8sJKPdDaGpQWtdw2GcrTPStD5HjVxr3YV7YseCo2d8XPoJa0avmUZjjr6zEoa+4W7v7BK55cBMiGdb5EetV/bKDjFTfq341k+SBVR/pECZHFh8ePK/UA72GyrUirX8bx9mDJ6Xz3/jmCjl3omFpTHuV8XFw==</SignatureValue>
<KeyInfo>
<X509Data>
<X509Certificate>MIIC8DCCAdigAwIBAgIQcjWMm4C6y5xJRUr9Yk1tezANBgkqhkiG9w0BAQsFADA0MTIwMAYDVQQDEylNaWNyb3NvZnQhdx7qeiLdQZwh/KlXXYWSlpmdxqNO/tS2ENCeg7gq9ziMY0ehUOr6tqFw5qMVm+G73RmSRSN3T08rFLOhiw4wb+xSwQgBrwtk9b97YIlJoQg2inbjHaR7dKY47vawwyH9XW10d7vtohezXg</X509Certificate>
</X509Data>
</KeyInfo>
</Signature>
<Subject>
<NameID Format="urn:oasis:names:tc:SAML:1.1:nameid-format:emailAddress">johndoe@mycompany.com </NameID>
<SubjectConfirmation Method="urn:oasis:names:tc:SAML:2.0:cm:bearer">
<SubjectConfirmationData InResponseTo="_bSzkMgnvnAUMhJiK" NotOnOrAfter="2026-07-27T23:47:10.540Z" Recipient="https://aws11-5.supportesriau.com.au/portal/sharing/rest/oauth2/saml/signin"/>
</SubjectConfirmation>
</Subject>
<Conditions NotBefore="2026-07-27T22:42:10.540Z" NotOnOrAfter="2026-07-27T23:47:10.540Z">
<AudienceRestriction>
<Audience>aws11-5.supportesriau.com.au.portal</Audience>
</AudienceRestriction>
</Conditions>
<AttributeStatement>
<Attribute Name="http://schemas.microsoft.com/identity/claims/tenantid">
<AttributeValue>redeacted</AttributeValue>
</Attribute>
<Attribute Name="http://schemas.microsoft.com/identity/claims/objectidentifier">
</Attribute>
<Attribute Name="http://schemas.microsoft.com/identity/claims/displayname">
<AttributeValue>John Doe</AttributeValue>
</Attribute>
<Attribute Name="http://schemas.microsoft.com/ws/2008/06/identity/claims/groups">
<AttributeValue>99999999-9999-9999-9999-999999999999</AttributeValue>
</Attribute>
<Attribute Name="http://schemas.microsoft.com/identity/claims/identityprovider">
<AttributeValue>https://sts.windows.net/792fc9a4-3964-41a1-8ec8-a09fef7088dd/</AttributeValue>
</Attribute>
<Attribute Name="http://schemas.microsoft.com/claims/authnmethodsreferences">
<AttributeValue>http://schemas.microsoft.com/ws/2008/06/identity/authenticationmethod/password</AttributeValue>
<AttributeValue>http://schemas.microsoft.com/ws/2008/06/identity/authenticationmethod/x509</AttributeValue>
<AttributeValue>http://schemas.microsoft.com/claims/multipleauthn</AttributeValue>
</Attribute>
<Attribute Name="http://schemas.xmlsoap.org/ws/2005/05/identity/claims/givenname">
<AttributeValue>John</AttributeValue>
</Attribute>
<Attribute Name="http://schemas.xmlsoap.org/ws/2005/05/identity/claims/surname">
<AttributeValue>Doe</AttributeValue>
</Attribute>
<Attribute Name="http://schemas.xmlsoap.org/ws/2005/05/identity/claims/emailaddress">
<AttributeValue>johndoe@mycompany.com</AttributeValue>
</Attribute>
<Attribute Name="http://schemas.xmlsoap.org/ws/2005/05/identity/claims/name">
</Attribute>
</AttributeStatement>
<AuthnStatement AuthnInstant="2026-07-27T21:28:24.571Z" SessionIndex="_722e4683-9660-4aa0-977b-70c9b8c81900">
<AuthnContext>
<AuthnContextClassRef>urn:oasis:names:tc:SAML:2.0:ac:classes:Password</AuthnContextClassRef>
</AuthnContext>
</AuthnStatement>
</Assertion>
</samlp:Response>
The following links to a document that contains a table listing SAML assertion values and the corresponding Portal for ArcGIS user properties.
Article ID: 000042900
Get help from ArcGIS experts
Start chatting now
