HOW TO
CURSORS: Creating cursor loops with AML
Procedure
Question
How to create a cursor loop to step through a selected set of records in an INFO file?
Answer
This can be done using the following steps:
1. Declare the cursor
In Arc and ArcPlot, give the cursor a name and a file to operate on. This is accomplished automatically in ArcEdit using the command EDIT or EDIFEATURE.
2. Select data
Use the selection commands in ArcPlot and ArcEdit (e.g. RESELECT, ASELECT, SELECT, etc.). In Arc, issue the selection statement when declaring the cursor.
3. Open the cursor
A newly opened cursor points to the first record of the selected set and sets a number of AML program variables. These variables fall into two categories: cursor variables and cursor descriptors. Cursor variables contain the data stored in the items of the selected record. Cursor descriptors store data about the file.
4. Start the loop
Use the cursor descriptor AML$NEXT to set up the loop. AML$NEXT is a keyword, and the variable reference syntax is:
:<cursor>.AML$NEXT
This variable is set to ".FALSE." if attempting to move the cursor past the end of the selected set of records or related records. The variable is set to ".TRUE." if the next record is successfully retrieved. Use &DO &WHILE to control access to the table. As long as the cursor is pointing to data, the loop continues.
5. Query and manipulate data
Use the CURSOR NEXT command to step through the selected set on a record-by-record basis. The CURSOR ... RELATE ... NEXT can be used to access related records. While accessing the records in the selected set, use cursor variables ( :<cursor>.<item_name> ) to report or update the data in each record.
6. Close the cursor
The cursor must be closed before changing the selected set. Close the cursor, change the selected set, and then reopen it for processing.
7. Remove the cursor
When finished using the cursor in Arc or ArcPlot, remove it from the session to free up system resources. Removing a cursor also closes it if the cursor had not been closed previously.
EXAMPLES
These three examples show how the same task is performed in Arc, ArcEdit, and ArcPlot. Suppose the INFO table landuse.pat has two items, lu-code and cost_ha, representing landuse code and cost per hectare, respectively. Industrial areas, represented by a landuse code of 200, have the cost per hectare changed from 15000 to 30000. The landuse.pat needs to be updated to reflect these changes. In every case where lu-code = 200, cost_ha needs to be changed from 15000 to 30000. In order to update landuse.pat using cursors, perform the following:
In ARC:
Arc: cursor
Usage: CURSOR <cursor> DECLARE <cover> <feature_class> {RO | RW} {logical_expression}
Usage: CURSOR <cursor> DECLARE <info_file> INFO {RO | RW} {logical_expression}
Usage: CURSOR <cursor> <OPEN | CLOSE | INSERT | DELETE | REMOVE>
Usage: CURSOR <cursor> <NEXT | FIRST | record_number>
Usage: CURSOR <cursor> RELATE <relate> <NEXT | FIRST | INSERT | DELETE>
CURSOR cur1 DECLARE landuse poly rw cost_ha = 15000
CURSOR cur1 OPEN
&DO &WHILE %:cur1.AML$NEXT%
&if %:cur1.lu-code% = 200 &then
&sv :cur1.cost_ha = 30000
CURSOR cur1 NEXT
&END
CURSOR cur1 CLOSE
CURSOR cur1 REMOVE
&RETURN
In ARCPLOT:
Arcplot: usage cursor
Usage: CURSOR <cursor> RELATE <relate> {NEXT | FIRST | INSERT | DELETE}
Arcplot:
CURSOR cur1 OPEN
&IF %:cur1.lu-code% = 200 &THEN
&SV :cur1.cost_ha = 30000
CURSOR cur1 NEXT
&END
CURSOR cur1 CLOSE
CURSOR cur1 REMOVE
In ARCEDIT:
Arcedit: usage cursor
Usage: CURSOR <OPEN | CLOSE | NEXT | FIRST | record_number>
Usage: CURSOR RELATE <relate> {NEXT | FIRST | INSERT | DELETE}
Arcedit:
SEL ALL
CURSOR OPEN
&DO &WHILE %:edit.AML$NEXT%
&IF %:edit.lu-code% = 200 &THEN
CURSOR NEXT
&END
CURSOR CLOSE
Article ID:000001380
Software:
  • Legacy Products
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
