HOW TO
Triangulated irregular networks (TIN) are a form of vector-based digital geographic data constructed by triangulating a set of vertices. The connection of the vertices with a series of edges forms a network of triangles. TIN surfaces can be created from vector data, raster data, and terrain datasets.
The instructions provided describe how to create TIN triangles from contour lines.
A 3D Analyst license is required to use the tools mentioned in the instructions below.
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012532/00N39000003LL2C-0EM39000000wdfL.png)
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012532/00N39000003LL2C-0EM39000000wdfF.png)
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012532/00N39000003LL2C-0EM39000000wdfR.png)
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012532/00N39000003LL2C-0EM39000000wdfH.png)
By using the constrained Delauney triangulation, the breaklines are not densified, and each breakline segment is added as a single edge.
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012532/00N39000003LL2C-0EM39000000wdfO.png)
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012532/00N39000003LL2C-0EM39000000wdfJ.png)
Article ID: 000012532
Get help from ArcGIS experts
Start chatting now
