HOW TO
The SDTSEXPORT command requires that a polygon coverage be provided which represents the bounding extent of the points being exported. This article provides the sequence of steps necessary to create the polygon coverage.
Code:
Arc: describe cities
Description of DOUBLE precision coverage cities
FEATURE CLASSES
Number of Attribute Spatial
Feature Class Subclass Features data (bytes) Index? Topology?
POINTS 22 110
SECONDARY FEATURES
Tics 4
TOLERANCES
Fuzzy = 0.002 N Dangle = 0.000 N
COVERAGE BOUNDARY
Xmin = 18.430 Xmax = 39.688
Ymin = 40.630 Ymax = 52.245
Code:
Arc: precision double double
Arc: generate boundingbox
Copyright (C) 1982-2002 Environmental Systems Research Institute, Inc.
All rights reserved.
GENERATE 8.3 (Wed Dec 18 08:17:08 PST 2002)
Generate: polygon
Enter polygons.
Terminate Polygons by entering END at X,Y: prompt.
Terminate input by entering END at ID,X,Y: prompt.
ID, {AUTO | X,Y}: 100
X,Y: 18.430,40.630
X,Y: 39.688,40.630
X,Y: 39.688,52.245
X,Y: 18.430,52.245
X,Y: 18.430,40.630
X,Y:
(Label for ID 100 placed at 29.059,47.154)
ID, {AUTO | X,Y}:
Generate: quit
Code:
Arc: build boundingbox poly
Building polygons...
Code:
Usage: PROJECTCOPY <COVER | GRID | FILE | TIN> <source>
<COVER | GRID | FILE | TIN> <target>
Arc: projectcopy cover cities cover boundingbox
Topological Vector Profile (TVP) is a subset of the Spatial Data Transfer Standard (SDTS), and TVP only allows the following external reference systems and units. If the data is in any other coordinate system than those listed below, the coverage must be projected before running SDTSEXPORT.
GEO - Lat/Long GEOGRAPHIC /* Geographic (latitude and longitude)
SPCS - meters STATEPLANE /* State Plane Coordinate Systems
UTM - meters UTM /* Universal Transverse Mercator
UPS - meters UPSTEREOGRAPHIC /* Universal Polar Stereographic
Code:
Usage: SDTSEXPORT <TVP | POINT | RASTER> <in_dataset> <out_transfer_prefix>
{in_point_cover} {out_DD_transfer} {Conv_Ctrl_File}
Arc: sdtsexport tvp boundingbox suf1 cities
Article ID:000006512
Get help from ArcGIS experts
Download the Esri Support App
