HOW TO
Create tabs for multiple embedded dashboards in ArcGIS Dashboards or ArcGIS Experience Builder
Last Published: June 29, 2022
Summary
Dashboards from ArcGIS Dashboards can be embedded in another dashboard or ArcGIS Experience Builder experience that share the same focus. Tabs can be created for these embedded dashboards in ArcGIS Dashboards or ArcGIS Experience Builder for easier access to view them.
This article provides instructions to create tabs for multiple embedded dashboards in ArcGIS Dashboards or ArcGIS Experience Builder.
Procedure
Use the Embedded Content option in ArcGIS Dashboards
  1. In ArcGIS Dashboards, click Create dashboard, fill in the required sections, and click the Create dashboard button in the lower-right corner.
  2. Click the Add element Icon of add element button button on the dashboard toolbar to open the element drop-down list.
  3. From the drop-down list, select the Embedded content option.
Elements drop-down list to select embedded content
  1. In the Embedded content window, under URL, paste the URL of the desired dashboard.
Dashboard's URL pasted on the embedded content window.
  1. Click Done in the window’s lower-right corner to add the dashboard to the current dashboard.
  2. Repeat Steps 2 through 5 to embed different dashboards.
  3. Create tabs by stacking the dashboards on top of each other. Refer to ArcGIS Dashboards: Tab elements for instructions.
Center position indicator to stack the dashboard on top of each other.
  1. Repeat Step 7 with the embedded dashboards.
The image below displays tabs created for multiple dashboards embedded in one ArcGIS Dashboards dashboard.
Multiple dashboards as tabs in one dashboard.
Use the Views Navigation widget in ArcGIS Experience Builder
  1. ​​​​​​In ArcGIS Experience Builder, click Create new, select the preferred template, and click Create.
  2. On the Insert widget panel, search for the Section widget, drag and drop it to the template.
  3. On the Insert widget panel, search for the Embed widget, drag and drop it to the section.
  4. On the right panel, on the Content tab, in Embed by URL, paste the URL for the dashboard.
  5. Click the section. On the Content tab, click New view. Select the View. Click Options The Options icon, and select Rename to rename the View.
  6. Repeat Steps 3 through 5 for the other dashboards.
  7. On the Insert widget panel, search for the Views Navigation widget, drag and drop it to the template.
  8. Click the Quick style Icon to select suitable design for the view. button to configure the design of the view.
  9. Click Save Icon to save the changes to the experience. to save the configurations.
The image below displays multiple dashboards embedded in one ArcGIS Experience Builder page that has tabs to view different dashboards.
Multiple dashboards as tabs on one experience.
Article ID: 000027769
Software:
  • ArcGIS Experience Builder
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
