HOW TO
Create stacked labels from text in the same field
Summary
This document illustrates creating stacked labels based on a single field. For example, a field with both city name and state name, such as "Anchorage Alaska", will be labeled as follows:
City: Anchorage
State: Alaska
This method does not work well for values with more than one space. For example, "Los Angeles California" will be labeled as:
City: Los
State: Angeles California
For values that do not contain a space, it will not label the feature.
Procedure
  1. Right-click the layer in the ArcMap Table of Contents and select Properties.
  2. Switch to the Labels tab.
  3. Click the Expression button.
  4. Check on the Advanced check box.
  5. Replace the existing code with the following:
Function FindLabel ( [City_State] )
  Dim theString, LeftStr, RightStr, ThePos
  theString = [City_State]
  ThePos = Instr(theString, " ") - 1
  LeftStr = Left (theString, ThePos)
  RightStr = Right (theString, Len(thestring) - ThePos)
  FindLabel = "City: "&LeftStr&VBNewLine&"State: "&RightStr
End Function
When using this code on your table, replace both occurrences of the City_State field name with the name of the field in your table.
  1. Click OK.
  2. Check the Label Features in this layer check box.
  3. in the Layer Properties dialog box, click Apply and click OK.
Article ID:000005022
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
