HOW TO
Create polygon between irregular edges of existing polygons in ArcMap
Summary
You can use the Editor's Auto Complete Polygon task twice to create and merge two adjacent polygons across the area between irregular edges of existing polygons.
Procedure
  1. Click Editor > Snapping. For the layer being edited, set snapping to Edge, Vertex, or both.
  2. Open the Task dropdown list and click Auto Complete Polygon.
  3. Create a polygon beginning and ending at the desired locations along one of the irregular edges. Extend the polygon about half way to the other irregular edge and square off the leading side with two vertices.
    [O-Image] Add polygon half way across gap
  4. Click Editor > Snapping. Make sure Vertex is checked for this layer.
  5. Create a polygon off the opposite complex edge. Snap to the two corner vertices of the polygon created in step three and complete the polygon at the desired location on the second irregular edge.
    [O-Image] Add another polygon to close gap
  6. For non-coverage data, select both new polygons and use Editor > Merge.
    For coverage polygons, use the shared edit tool
    Shared edit tool icon is on the Editor toolbar
    [O-Image] Shared edit tool icon
    to select their common border arc. Then delete it.
Article ID:000002302
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
