HOW TO
Create fractions as labels using Arcade in ArcGIS Pro
First Published: June 1, 2023
Last Published: April 7, 2026
Summary
In ArcGIS Pro, labelling a feature class with fractions can be an efficient method to represent statistical analysis. For example, it can be used to determine the number of activated cellular towers over the total number of installed cellular towers in a town.
This article describes the workflow to create the fractions as labels using ArcGIS Arcade in ArcGIS Pro.
Procedure
  1. Open the ArcGIS Pro project, add the layer, and create a label expression. Refer to Steps 1 through 4 in ArcGIS Pro: Write a label expression for instructions. Select Arcade for Language.
In the Contents pane, on the List By Labeling tab, ensure the selected feature layer and feature class check boxes are checked to display the labels.
  1. Insert and configure the expression below in the Expression box. Replace <fieldName1> and <fieldName2> with the field names of the layer. In this example, 'MIN' and 'MAX' are used.
var numerator = $feature.MIN;
var denominator = $feature.MAX; return `<align horizontal ='center'><UND>${numerator}</UND>${TextFormatting.NewLine}${denominator}</align>`
  1. Click the Verify icon to validate the expression.
  2. Uncheck the Remove extra spaces check box.
  3. Click Apply to run the script.
Writing the label expression to generate fractions
The map below shows the fractions displayed as labels in ArcGIS Pro.
Fractions as labels are created
Article ID: 000030522
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
