HOW TO
Create enlarged outlines for polygons in ArcMap
First Published: December 6, 2017
Last Published: July 2, 2020
Summary
It is often desirable to do customize symbology, such as creating expanded outlines, or outlines that are offset from the original polygon by a certain amount.
This article describes the steps to create offset outline symbology for a polygon, as shown in the image below.
This can only be done with a cartographic line symbols, which can be selected as the line type in the deeper symbology settings.
image of polygons with offset margins
Procedure
  1. Open Symbol Selector by clicking the symbol in the Table of Contents.
  2. Click Edit Symbol.
  3. Select the blue line 'layer' in the symbol property editor.
  4. Click Outline.
  5. Click Edit Symbol.
  6. Select Type: Cartographic Line Symbol
  7. Click the Line properties tab.
  8. Adjust the value for Offset here to adjust how 'enlarged' the outline symbology for the polygon appears, relative to the polygon itself.
User-added image
Article ID: 000017114
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
