HOW TO
Create custom variables from an Excel file in ArcGIS Business Analyst
First Published: March 18, 2026
Last Published: June 26, 2026
Summary
In the ArcGIS Business Analyst web app, a custom infographic may show variables as N/A. Follow these steps to create new custom variables from an Excel sheet.
Procedure
  1. Log into ArcGIS Business Analyst.
    1. Go to Maps > Add data > Import file.
    2. Browse to and select the Excel file.
    3. Leave the default settings and click Next.
    4. Click Save, then I'm Done.
  2. Set up custom data.
    1. Navigate to Maps > Add data > Custom data setup.
    2. Click Get started > Start setup.
    3. Choose the layer from the map, then click Next.
    4. Drag and drop the desired field into the Category pane on the right.
    5. Click Save, then I'm Done.
  3. Create a custom variable:
    1. Go to Reports > Build Infographics > My templates.
    2. Click Open > Edit.
    3. Click Edit/Add Variable > Create a custom variable.
    4. Select Advanced custom variable > My variables.
    5. Click Add, then Save.
Article ID: 000038424
Software:
  • ArcGIS Business Analyst Web App
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
