HOW TO
Create .ACODE INFO file for line coverage input to ARCDFAD
Summary
A description of the .ACODE INFO file and its item definitions for ARCDFAD conversion.
Procedure
The .ACODE file must have the following items:
ITEM NAME        WIDTH OUTPUT  TYPE
FACODE 4 5 B
HEIGHT 4 5 B
FICODE 4 5 B
SMCCODE 4 5 B
DIRECT 1 1 I
WIDTH 2 3 B
The .ACODE item FACODE must have values which are related to the DSnnnL-ID found in the .AAT. Appropriate values for the remaining items must be determined from the DFAD format specifications. See Related Information to find out how to obtain those specifications.
You could use AML to automate the creation of the .ACODE file.
/* NAME: ACODE.AML
/* USAGE: &RUN ACODE.AML
/* NOTES:
/* Run this AML from the Arc prompt.
/* Run this AML from a directory that is NOT the workspace
/* directory that will be converted with ARCDFAD
/* This is not an ESRI supported AML. Please use at your own risk.
/* Also, please make a backup of your data before running this AML
/* and carefully check the output. This is just a skeleton AML with
/* no real error checking. It is meant only as a guide to developing an
/* AML specific to your data inputs and desired outputs.
&args worksp incov
&sv orig_work = [show &workspace]
&workspace %worksp%
&if ^ [exist %incov% -cover] &then
&type Coverage %incov% not found.
&else
&do
tables
define %incov%.acode
facode,4,5,b
height,4,5,b
ficode,4,5,b
smccode,4,5,b
direct,1,1,i
width,2,3,b
quit
&end
&workspace %orig_work%
&return
If the DSnnnL coverage has not been built for LINE, it is not necessary to create a .ACODE file, but the lines will not be converted to DFAD.
The ArcInfo DFAD translator supports DFAD levels 1, 2, 1-C, and 3-C only. Check with your data provider to determine what DFAD level you have.
Article ID:000002393
Software:
  • Legacy Products
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
