HOW TO
Note: The information in this article applies to a retired product, ArcInfo Workstation. For further guidance, see the Related Information section.
The geospatial information contained in the GeoTIFF file can be used to generate a world file. There are third party utilities that can be used to extract worldfile information from a GeoTIFF image. A search on the internet can locate these. If ArcInfo Workstation is available, the procedure described herein provides another approach.
The following AML extracts the spatial information from a GeoTIFF image and creates a worldfile. To make this function available from any Arc session, regardless of workspace, copy the AML in the $ARCHOME/atool/arc directory.
/* worldfile.aml 1.0 Sep 7 '00 /*********************************************************************/ /* NAME: worldfile.aml /* MODULE: Arc /* PURPOSE: Extracts the spatial information from a GeoTIFF image /* and creates a world file. /* /* Usage: WORLDFILE <In_Image> {Out_Worldfile} /* /* - When no Out_Worldfile name is specified, the name of /* the input image will be used. /* - The AML will not overwrite an existing world file. /* /* Note: Do not use .tfw extension on output worldfile name. It /* will be applied automatically. /* /* This is not an ESRI supported AML. Please use at your own risk. /* Also, please make a backup of your data before running this AML /* and carefully check the output. This is just a skeleton AML with /* no real error checking. It is meant only as a guide to developing an /* AML specific to your data inputs and desired outputs. /*********************************************************************/ &args in_image out_wrld &if [null %in_image%] and [null %out_wrld%] &then &goto usage &if [null %out_wrld%] &then &do &sv out_wrld = %in_image% &end /* check if file already exists &if [exists %out_wrld%.tfw -file] &then &do &type ' Specified output worldfile name already exists.' &return &pause &end /* obtain spatial parameters of image &describe %in_image% /* calculate values to be used in output worldfile &sv xdim = %IMG$DX% &sv ydim = %IMG$DY% &sv xul = [calc %IMG$XMIN% + [calc %IMG$DX% / 2 ]] &sv yul = [calc %IMG$YMAX% - [calc %IMG$DX% / 2 ]] /* write world file &sv worldfile = [open %out_wrld%.tfw openstat -write] &sv writestat = [write %worldfile% %xdim%] &sv writestat = [write %worldfile% 0.000000000000] &sv writestat = [write %worldfile% 0.000000000000] &sv writestat = [write %worldfile% -%ydim%] &sv writestat = [write %worldfile% %xul%] &sv writestat = [write %worldfile% %yul%] &sv closestat = [close %worldfile% ] &return /* display usage &label usage &type ' ' Usage: WORLDFILE <In_Image> {Out_Worldfile} &return
Article ID:000002115
Get help from ArcGIS experts
Download the Esri Support App
