HOW TO
Create a sorted list of unique values from a table or feature class
Summary
Instructions provided describe how to create a sorted list of unique values from a table or feature class. A sorted list of unique values can be created by first sorting a table based on the column of interest and then generating a list of unique values. Normally, a list of unique values is in the order of occurence of the unique value. If the table is in order, each value is encountered in order and produces an ordered list.
Procedure
The sample VB code below uses Counties data for the United States and retrieves a sorted list of unique values. The code prints the values to DEBUG for simplicity.
  1. Create a IFeatureClass object. This can be any workspace type (Coverage, Shapefile, Personal Geodatabase, or Geodatabase).
    Geodatabase
    Code:
    Dim pWorkspace As IWorkspace
    Dim pWorkspaceFactory As IWorkspaceFactory
    Set pWorkspaceFactory = New SdeWorkspaceFactory
    Dim pPropertySet As IPropertySet
    Set pPropertySet = New PropertySet
    With pPropertySet
    .SetProperty "Server", "testserver"
    .SetProperty "Instance", "5253"
    .SetProperty "Database", "sde"
    .SetProperty "user", "example"
    .SetProperty "password", "example"
    .SetProperty "version", "sde.DEFAULT"
    End With
    Set pWorkspace = pWorkspaceFactory.Open(pPropertySet, Me.hWnd)
    Dim pFeatureWorkspace As IFeatureWorkspace
    Set pFeatureWorkspace = pWorkspace
    Dim pFeatureClass As IFeatureClass
    Set pFeatureClass = pFeatureWorkspace.OpenFeatureClass("Counties")
    Code:
    Set pWorkspaceFactory = New AccessWorkspaceFactory
    Set pWorkspace = pWorkspaceFactory.OpenFromFile("D:\Data\example.mdb", 0)
    Shapefile
    Code:
    Set pWorkspaceFactory = New ShapefileWorkspaceFactory
    Set pWorkspace = pWorkspaceFactory.OpenFromFile("D:\Data", 0)
    Coverage
    Code:
    Set pWorkspaceFactory = New ArcInfoWorkspaceFactory
    Set pFeatureClass = pFeatureWorkspace.OpenFeatureClass("Counties:polygon")
  2. Set up an IFeatureCursor to retrieve the field value in order (sorted).
    Code:
    Dim sFieldName as String
    sFieldName = "state_name"
    Dim pTableSort As ITableSort
    Set pTableSort = New esriGeoDatabase.TableSort ' ArcGIS 9.X
    'Set pTableSort = New esriCore.TableSort ' ArcGIS 8.x
    With pTableSort
    .Fields = sFieldName
    .Ascending(sFieldName) = True
    .CaseSensitive(sFieldName) = False
    Set .QueryFilter = Nothing
    Set .Table = pFeatureClass
    End With
    pTableSort.Sort Nothing
    Dim pFeatureCursor As IFeatureCursor
    Set pFeatureCursor = pTableSort.Rows
  3. Set up the IDataStatistics object to retrieve unique values.
    Code:
    Dim pDataStatistics As IDataStatistics
    Set pDataStatistics = New DataStatistics
    pDataStatistics.Field = sFieldName
    Set pDataStatistics.Cursor = pFeatureCursor
    Dim pEnumVar As IEnumVariantSimple
    Set pEnumVar = pDataStatistics.UniqueValues
  4. Retrieve unique values.
    Code:
    Dim value As Variant
    value = pEnumVar.Next
    Do Until IsEmpty(value)
    Debug.Print value
    Loop
  5. Complete code for a shapefile.
    Code:
    'Set pTableSort = New esriCore.TableSort 'ArcGIS 8.X
    Set pTableSort = New TableSort 'ArcGIS 9.X
    With pTableSort
    End With
    Debug.Print value
    Loop
Article ID:000004604
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
