HOW TO
In ArcGIS Online and Portal for ArcGIS Map Viewer, pop-ups configured by Arcade expressions with multiple statements can be used to display and sort field names and values across multiple fields of a feature. This makes it easier to determine which product or issue has the highest or lowest incident within a polygon. This article provides an example and instructions using Arcade expressions to create a pop-up with field names and values from multiple fields sorted in descending order in Map Viewer.
The image below shows a Map Viewer pop-up with each field and records separated.
function Comp (a, b) { When( IsEmpty(a[1]), -1, IsEmpty(b[1]), 1, Iif(a[1]>b[1], 1, -1) ); };
var <variableName1> = [ ["<fieldName1>", $feature.<fieldName1>], ["<fieldName2>", $feature.<fieldName2>], ["<fieldName3>", $feature.<fieldName3>], ["<fieldName4>", $feature.<fieldName4>], ["<fieldName5>", $feature.<fieldName5>], ["<fieldName6>", $feature.<fieldName6>], ["<fieldName7>", $feature.<fieldName7>], ["<fieldName8>", $feature.<fieldName8>], ["<fieldName9>", $feature.<fieldName9>], ];
<variableName1> = Reverse(Sort(<variableName1>, Comp));
var <variableName2> = ""; for (var i in <variableName1>) { if (<variableName2> == "") { <variableName2> = Replace(Replace(Replace(<variableName1>[i], '["', ""), '",', ": "), ']', ""); } else { <variableName2> += TextFormatting.NewLine + Replace(Replace(Replace(<variableName1>[i], '["', ""), '",', ": "), ']', ""); } } return <variableName2>;
The code block below is an example of the full working expression.
function Comp (a, b) { When( IsEmpty(a[1]), -1, IsEmpty(b[1]), 1, Iif(a[1]>b[1], 1, -1) ); }; var arr = [ ["BREASTCANCER", $feature.BREASTCANCER], ["CARDIOVASCULAR", $feature.CARDIOVASCULAR], ["CERVICALCANCER", $feature.CERVICALCANCER], ["COLONCANCER", $feature.COLONCANCER], ["DIABETES", $feature.DIABETES], ["INFLUENZA", $feature.INFLUENZA], ["LUNGCANCER", $feature.LUNGCANCER], ["PROSTATECANCER", $feature.PROSTATECANCER], ["SKINCANCER", $feature.SKINCANCER], ]; arr = Reverse(Sort(arr, Comp)); var result = ""; for (var i in arr) { if (result == "") { result = Replace(Replace(Replace(arr[i], '["', ""), '",', ": "), ']', ""); } else { result += TextFormatting.NewLine + Replace(Replace(Replace(arr[i], '["', ""), '",', ": "), ']', ""); } } return result;
The image below shows the newly added Diseases-Sorted field with multiple field names and values sorted in a descending order in the pop-up after using the Arcade expression.
Article ID: 000029130
Get help from ArcGIS experts
Download the Esri Support App
