Summary
Instructions provided demonstrate how to create a Military Analyst DTED catalog with raster files in a format other than DTED.
Procedure
Before getting started ensure that Military Analyst is installed and that the extension is turned on: Tools > Extensions.
- Start ArcCatalog.
- Create a new personal geodatabase (pGDB).
- Right-click on the pGDB and select New > MA Catalog.
- Complete the following:
A. Specify a name for the catalog.
B. Leave the Input Folder option blank.
C. Specify DTED catalog.
D. Click OK. - Right-click on the the newly created catalog and select load > load data.
- Select the images to be loaded as the Input Rasters. These rasters should all have the same projection.
- A. Specify the ouput catalog as the newly created catalog.
B. Click OK to run the Raster to Geodatabase tool. - Start ArcMap.
- Load the MA toolbar: View > Toolbars.
- A. Click on the 'Add Data' button (yellow diamond with black cross) and navigate to the MA catalog in the personal geodatabase.
B. Add this layer to ArcMap. - Start an edit session.
- Right-click on the catalog in the table of contents and open the attribute table.
- Right-click on the heading DTED_TYPE and select 'calculate values'.
- A. Enter "DTED 0" [include quotes; zero; not the letter 'o'] into the bottom window .
B. Click OK to run the field calculator. - Close the attribute table, stop the edit session.
- A. Remove the layer from the map. Click the 'Add MA Layer' button (green diamond with black cross) and navigate to the MA catalog in the personal geodatabase.
