HOW TO
Create a data dictionary of a file geodatabase using the X-Ray for ArcCatalog add-in
First Published: September 29, 2016
Summary
Data dictionary is a catalog or table containing information about the datasets stored in a database. The data dictionary might contain the full names of attributes, meanings of codes, scale of the source data, accuracy of locations, and map projections used. Creating a data dictionary allows other users in an organization to view the information about the data.
Data dictionaries are also available online. However, at times users are not using the latest version, therefore the database schema is different. The X-Ray for ArcCatalog add-in provides the tools to create an HTML document of the data dictionary for any database.
The following instructions describe how to create a data dictionary of a file geodatabase using the X-Ray for ArcCatalog add-in.
The X-Ray for ArcCatalog add-in requires an ArcGIS Desktop Standard or Advanced license.
Procedure
Ensure data is in a file geodatabase before creating a data dictionary and the extension for X-Ray Extension for Geodatabases is enabled.
  1. In ArcCatalog, click the X-Ray window button to open the X-Ray for Geodatabases window.
Click the X-Ray window button.
  1. In Catalog Tree, select the file geodatabase for the data dictionary creation. This populates the geodatabase field in the X-Ray for Geodatabases window.
User-added image
  1. Click the Export GDB to XML Workspace button.
User-added image
  1. Click View > Data Dictionary.
Click the View menu, and click Data Dictionary.
The HTML file of the geodatabase documentation opens in a web browser.
Geodatabase documentation is opened in a web browser such as Google Chrome.
Article ID: 000014210
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
