HOW TO
Create a basin model using a digital elevation model (DEM) in ArcGIS Pro
Last Published: February 16, 2023
Summary
The Basin (Spatial Analyst) tool in ArcGIS Pro creates a delineated drainage basin raster by identifying ridge lines between basins. This is useful for understanding an area’s drainage system by identifying where and how many drainage basins are located within the area.
The following article provides a workflow to create a basin model using a digital elevation model (DEM) in ArcGIS Pro.
Procedure
The workflow below requires the Spatial Analyst license. Refer to ArcGIS Pro: Enable the Spatial Analyst extension for more information.
  1. Run the Fill tool on the DEM to fill the sinks in the surface raster and remove small imperfections in the data.
    1. In ArcGIS Pro, navigate to Analysis > Tools to open the Geoprocessing pane.
    2. In the Geoprocessing pane, search for and click the Fill (Spatial Analyst) tool.
Searching for and selecting the Fill tool in the Geoprocessing pane
  1. On the Parameters tab of the Fill pane, select a DEM for the Input surface raster parameter. In this example, the River Systems layer is selected.
  2. Verify the path name for the Output surface raster parameter. In this example, ‘RiverSystemFill’ is named.
Configuring the Fill tool parameters
  1. Input the Z limit if necessary. Refer to ArcGIS Pro: Fill (Spatial Analyst) for more information on the tool parameters.
  2. Click Run.
The image below is a before and after comparison of small imperfections in the DEM layer corrected with the Fill tool.
A before and after comparison of small imperfections in the DEM corrected with the Fill tool
  1. Run the Flow Direction tool.
    1. In the Geoprocessing pane, search for and select the Flow Direction (Spatial Analyst) tool.
Searching for and selecting the Flow Direction tool in the Geoprocessing pane
  1. On the Parameters tab of the Flow Direction pane, select the output from Step 1 for the Input surface raster parameter. In this example, the RiverSystemsFill layer is selected.
  2. Verify the path name for the Output flow direction raster parameter. In this example, 'FlowDirectOut' is named.
Configuring the Flow Direction tool parameters
  1. Click Run.
The image below shows the output layer after running the Flow Direction tool.
The output layer of the Flow Direction tool
  1. Run the Basin tool.
    1. In the Geoprocessing pane, search for and select the Basin (Spatial Analyst) tool.
Selecting the Basin tool from the Geoprocessing pane
  1. On the Parameters tab of the Basin pane, select the output from Step 2 for the Input D8 flow direction raster parameter. In this example, the FlowDirectOut layer is selected.
  2. Verify the path name for the Output raster parameter. In this example, ‘BasinModel’ is named.
Configuring the Basin tool parameters
  1. Click Run.
The image below shows the basin model after running the Basin tool. Each basin is represented with a different color.
The output of the Basin tool marks each basin with a different color
Article ID: 000029394
Software:
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
