HOW TO
Copy isodatetime values in a string field to date values in a date field
Summary
This article demonstrates how to use the Field Calculator to copy isodatetime values in a table's string field to date values in a date field.
Procedure
The 'Hiredate' field represents the string field with the isodatetime values and the 'NewDate' field represents the date defined field with the date values.
  1. Open the table in ArcView.
    A. Activate the Project window.
    B. Click the Tables icon.
    C. Click the Add button.
    D. Set List Files of Type to appropriate file type.
    E. Navigate to the location of the table.
    F. Select the table.
    G. Click OK.
  2. Add a date field to the table.
    A. Select Start Editing from the Table menu.
    B. Select Add Field from the Edit menu.
    C. In the Field Definition dialog box:
    1. Set Name to an appropriate name, for example 'Date'.
    2. Set Type to Date.
    D. Click OK.
    E. Select Stop Editing from the Table menu and save the edits.
  3. Activate the string field with the isodatetime values.
    [O-Image] isodatetime active
  4. Enter the following code into the expression text box on the Field Calculator dialog box and click OK.
    Code:
    [Hiredate].Extract(0).Substitute( "-", "")
    Hiredate is the name of the string field containing the isodatetime values.
    [O-Image]isodatetime field calculator
  5. Make the new date field active.
    [O-Image] isodatetime new date values
  6. Enter the following code into the expression text box on the Field Calculator dialog box and click OK.
    Code:
    [Hiredate].AsNumber.AsDate
    [O-Image] isodatetime field calculator new date
Article ID:000005034
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
