HOW TO
Copy and paste a feature to another feature layer in Collector for ArcGIS (Android)
Last Published: July 28, 2025
Summary
In Collector for ArcGIS, it is possible to copy an existing feature and paste it to a new layer. This saves time and reduces errors when collecting data on the field. However, Collector for ArcGIS only allows copying and pasting features to another feature layer within the same map.
The functionalities of ArcGIS Collector, ArcGIS Explorer, and ArcGIS Tracker are now available in ArcGIS Field Maps. There are no new capabilities planned for these apps—all future updates will be focused on Field Maps. Migration is recommended. See ArcGIS Blog: Migrate to Field Maps for more information.
Procedure
The workflow below describes how to copy and paste a feature to another feature layer in Collector for ArcGIS (Android).
  1. In Collector for ArcGIS, open the map containing the features and select the feature to copy.
  2. The result of the selected feature is displayed at the bottom of the map. Click the List icon to view the details of the selected feature if desired.
    Feature detail
  3. In the results list, select the arrow icon at the bottom right > Copy.
    Result action
  4. Select the At the same location option. This opens a Collect a new feature dialog box. In the dialog box, select the desired layer to paste the copied feature.
    Copy to another layer
  5. Click the List icon to view the copied feature, which is at the same location, but in a different layer.
    Copied feature in a different layer
Article ID: 000017946
Software:
  • ArcGIS Collector
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
