HOW TO
The script in this article takes a polygon or polyline theme and break it into a line theme with a separate feature for each line segment.
Code:
'-- Pgn2Line.ave
'-- This script takes a polygon or polyline theme and
'-- extracts each individual line segment between vertices.
'-- The list of these line segments is used to create a
'-- new line theme.
theView=av.getactivedoc
theTheme=theView.getactivethemes.get(0)
theFtab=theTheme.getftab
theFtabCount=theFtab.getnumrecords
thesf=theFtab.FindField("Shape")
theNewLOL={}
for each r in theftab
av.ShowMsg("Counting line segments...")
av.SetStatus(((r+1)/theFtabCount) * 100)
thePg=theftab.returnvalue(thesf,r)
theNewLOP={}
theLOLOP=thePG.aslist
for each l in theLOLOP
theLOP=l.aslist
for each thept in theLOP
theNewLOP.Add(thept)
end
end
theNewLOPcount=theNewLOP.Count
pt1i=0
pt2i=1
for each apt in 2..theNewLOPcount
pt1=theNewLOP.Get(pt1i)
pt2=theNewLOP.Get(pt2i)
theNewLine=Line.Make(pt1, pt2)
theNewLOL.Add(theNewLine)
pt1i=pt1i+1
pt2i=pt2i+1
end
end
av.clearmsg
av.clearstatus
'-- Make the new polyline shapefile
theNewLOLcount=theNewLOL.Count.asstring
msgbox.info("The line theme will have"++theNewLOLcount++"lines in it","Almost done")
out_name = FileDialog.Put( "*.shp".asfilename, "*.shp", "Output Shapefile")
if (out_name = nil) then
exit
end
myidfld = Field.Make("myID",#FIELD_LONG,6,0)
fields = List.Make
Fields.Add(myIDfld)
tblrecno=0
'-- Create the new Ftab and add fields
tbl = Ftab.MakeNew( out_name, Polyline )
tbl.AddFields( fields )
'-- Add the records, ID value, and polyline to the ftab
for each npl in 0..(theNewLOL.count-1)
av.showmsg("Creating new shapefile"++out_name.asstring++"...")
av.setstatus(((npl+1)/theNewLOLcount.asnumber) *100)
tbl.addrecord
tbl.SetValue(myIDfld, npl, npl)
tbl.SetValue(tbl.FindField("Shape"), npl, theNewLOL.Get(npl).aspolyline)
end
theNewFtheme=Ftheme.Make(tbl)
theView.AddTheme(theNewfTheme)
theNewFtheme.SetVisible(true)
theNewFtheme.SetActive(true)
thetheme.SetVisible(false)
thetheme.setactive(false)
theview.Invalidate
av.clearmsg
av.clearstatus
msgbox.Info("Finished!","")
This script will not work with island polygons.
Article ID:000004028
Get help from ArcGIS experts
Download the Esri Support App
