HOW TO
The ArcView sample script cvtplypl.ave converts the active polygon vector theme into a new polyline shapefile. However, if a polygon has multiple parts, this script only converts the first part. This document provides a sample script that will convert all parts of a multi-part polygon to polylines.
Code:
'--- Script: MPpoly2line.ave
'--- This script converts selected polygons in the active them to polylines
'-- to create a new shapefile. If no features are currently selected all polygons
'-- will be processed. This script is modified from the "cvtplypl.ave" sample
'-- script that comes with ArcView GIS 3.0 and supports multi-part polygons
'--- This script requires: a View must be the active document, a polygon theme
'-- must be the active theme. Use the following as an update script:
'-Update script for control...
'-v = av.GetActiveDoc
'-t = v.GetActiveThemes.Get(0)
'-SELF.SetEnabled((t <> NIL) AND
'- (t.GetFTab.FindField("shape").GetType = #FIELD_SHAPEPOLY))
' Self:
' Returns:
theView = av.GetActiveDoc
thmThemeIn = theView.GetActiveThemes.Get(0)
'--- Specify the output shapefile...
fnDefault = FileName.Make("$HOME").MakeTmp("shape","shp")
fnOutput = FileDialog.Put( fnDefault,"*.shp","Output Shape File" )
if (fnOutput = nil) then exit end
fnOutput.SetExtension("shp")
ftbOutput = FTab.MakeNew( fnOutput, POLYLINE )
ftbOutput.AddFields({Field.Make("ID", #FIELD_LONG, 8, 0)})
'--- Use selected shapes if there are any, otherwise iterate through the entire
FTab
if (thmThemeIn.GetFTab.GetSelection.Count > 0) then
colToProcess = thmThemeIn.GetFTab.GetSelection
nRecs = colToProcess.Count
else
nRecs = colToProcess.GetNumRecords
end
nCount = 0
nRecsAdded = 0
fldShapeIn = thmThemeIn.GetFTab.FindField("shape")
fldShapeOut = ftbOutput.FindField("shape")
fldIDOut = ftbOutput.FindField("id")
for each r in colToProcess
nCount = nCount + 1
av.SetStatus((nCount / nRecs) * 100)
shpIn = thmThemeIn.GetFTab.ReturnValue(fldShapeIn,r)
i = -1
for each plinePart in shpIn.AsList
i = i + 1
shpNew = Polyline.Make({shpIn.AsList.Get(i)})
nRecNew = ftbOutput.AddRecord
ftbOutput.SetValue(fldShapeOut,nRecNew,shpNew)
ftbOutput.SetValue(fldIDOut,nRecNew,nCount)
nRecsAdded = nRecsAdded + 1
end
end
ftbOutput.SetEditable(false)
av.SetStatus(100)
if (nRecsAdded = 0) then
MsgBox.Error("Unable to convert polygons to polylines.","Convert Polygon to Polyline")
exit
else
MsgBox.Info(nRecsAdded.AsString++"shapes converted.","Convert Polyline to Polygon")
end
if (MsgBox.YesNo("Add shapefile as theme to a view?","Convert Polygon to Polyline", true).Not) then
exit
end
'--- Create a list of views and allow the user to choose which view to
'-- add the new theme to...
lstViews = {}
for each d in av.GetProject.GetDocs
if (d.Is(View)) then
lstViews.Add( d )
end
end
lstViews.Add("<New View>")
vweAddTo = MsgBox.ListAsString( lstViews,"Add Theme to:","Convert Polyline to Polygon" )
'--- Get the specified view, make the theme, and add it...
if (vweAddTo <> nil) then
if (vweAddTo = "<New View>") then
vweAddTo = View.Make
vweAddTo.GetWin.Open
end
thmNew = FTheme.Make( ftbOutput )
vweAddTo.AddTheme( thmNew )
vweAddTo.GetWin.Activate
end
'--- End of script: MPpoly2line.ave
Article ID:000005213
Get help from ArcGIS experts
Download the Esri Support App
