HOW TO
In some cases, the GeoEvent log files are converted to Excel for multiple purposes. For example, for filtering different types of errors, or to create a count summary based on unique error messages.
The following steps demonstrate how to convert GeoEvent logs to Excel and summarize unique message by count using a Python script.
Note: The script creates two files, analyzed and message_count.
import os import pandas as pd
log_dir = r'C:\Program Files\ArcGIS\Server\GeoEvent\data\log' log_path = [os.path.join(log_dir, log_file) for log_file in os.listdir(log_dir)]
i=1
for path in log_path:
if path.endswith('karaf.log'):
df = pd.read_table(path,
sep='|',
header=None,
names=['level', 'unknown1', 'unknown2','logger', 'message'],
parse_dates=True, error_bad_lines = False, warn_bad_lines = True)
df.to_excel(os.path.join(log_dir, 'analyzed{}.xlsx'.format
count = df['message'].value_counts() count.to_excel(os.path.join(log_dir, 'message_count.xlsx'))The following code sample demonstrates a full working script:
import os
import pandas as pd
# Define Log Directory
#for log_file in os.listdir(log_dir):
#log_path = os.path.join(log_dir, log_file)
#print(log_path)
# Convert to Excel
i=1
sep='|',
header=None,
df.to_excel(os.path.join(log_dir, 'analyzed{}.xlsx'.format(i)))
i+=1
# Summarize by count
Note: The code can be used as a standalone script. To do so, copy the full script into a text editor, for example, Notepad++, and save the file as a .py file. To run the code, right-click the .py file and select Edit with IDLE > Select Run > Run Module.
Article ID: 000018954
Get help from ArcGIS experts
Start chatting now
