HOW TO
Convert Decimal Degree values to Degree Minute Seconds values using the Field Calculator
Last Published: October 20, 2023
Summary
Python scripts are specific to the version of Python that was shipped with the version of ArcMap in use. Therefore, this script may not work with your version of ArcMap. However, this script may serve as a template for modification, if desired.
Refer to FAQ: What version of Python is used in ArcGIS? for more information.
To perform coordinate conversion, Esri recommends using the Convert Coordinate Notation tool in ArcToolbox > Projections and Transformations toolset.
Instructions provided describe how to use the Field Calculator to convert Decimal Degrees stored in a numeric field to Degrees Minutes Seconds stored in a text field. The output by default is in the following format:
DD°MM'SS.SS"N
Procedure
Follow the steps below:
  1. Add the table to ArcMap.
  2. Right-click the table in the Table of Contents and select Open.
  3. Verify that Edit mode is not enabled. Click the Options button and select Add Field.
  4. Type DMSLat in the Name field and select Text from the Type drop-down list. If DMSLat is already used as a field name, select a name that is not being used.
  5. Change the length to 20.
  6. Right-click on the DMSLat field and select Calculate Values.
  7. Click Yes if presented with a message box.
  8. Change the Parser from VB Script to Python.
  9. Check the box to Show Codeblock.
  10. Paste the following code into the Pre-Logic Script Code box:
def decimalDegrees2DMS(value,type):
        Converts a Decimal Degree Value into
        Degrees Minute Seconds Notation.
        Pass value as double
        type = {Latitude or Longitude} as string
        returns a string as D:M:S:Direction
        created by: anothergisblog.blogspot.com
    degrees = int(value)
    submin = abs( (value - int(value) ) * 60)
    minutes = int(submin)
    subseconds = abs((submin-int(submin)) * 60)
    direction = ""
    if type == "Longitude":
        if degrees < 0:
            direction = "W"
        elif degrees > 0:
            direction = "E"
        else:
            direction = ""
    elif type == "Latitude":
        if degrees < 0:
            direction = "S"
        elif degrees > 0:
            direction = "N"
        else:
            direction = ""
    notation = str(degrees) + u"\u00b0" + str(minutes) + "\'" +\
               str(subseconds)[0:5] + "\"" + direction
    return notation
  1. Paste one of the following code into the DMSLat = expression box at the bottom of the dialog box depending on the desired latitude or longitude data.
decimalDegrees2DMS( !Latitude_Field_Name! ,"Latitude")
decimalDegrees2DMS( !<Longitude_Field_Name! ,"Longitude")
  1. Click OK to run the Field Calculator.
  2. Repeat steps 3 through 12 for the longitude values, but change the first parameter in the DMSLong expression box to the field in the table that contains the longitude decimal degree values and replace the word Latitude in the second parameter with the word Longitude.
Article ID: 000008758
Software:
  • ArcMap 10 6
  • ArcMap 10 x
  • ArcMap 10 7
  • ArcMap 10 8
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
