HOW TO
Convert a route coverage into a coverage using ROUTEARC
Summary
Instructions provided describe how to convert a route coverage into a line coverage using the ROUTEARC command in ArcInfo Workstation.
Procedure
Use the following syntax for ROUTEARC:
Code:
ROUTEARC <in_cover> <route_system> <out_cover>
  • <in_cover>: Specify the route coverage to be converted.
  • <route_system>: View the route coverage in ArcCatalog to see 'route.<name of original feature class>'. Use everything that appears after 'route.' as the <route_system>.
    For example, a feature class called roads exported into a coverage displays the following in ArcCatalog.
    arc
    route.roads
    tic
    In this example, use 'roads' as the <route_system>.
  • <out_cover>: Type in a new unique coverage name.
Article ID:000008771
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
