HOW TO
Convert a geodatabase feature class and annotation to a CAD file
Summary
Instructions provided describe how to convert a geodatabase feature class and annotation to a CAD file.
An ArcInfo license is required for this type of conversion.
Procedure
Follow the steps below to create geodatabase annotation and convert the geodatabase feature class and annotation to a CAD file.
  1. Start ArcMap.
  2. Add the geodatabase feature class to ArcMap.
  3. Right-click the layer in the table of contents and select Label Features to label the features.
  4. Convert the labels to annotation and store them in the geodatabase.
    A. Right-click the layer in the ArcMap table of contents.
    B. Select Convert Labels to Annotation.
    C. Select Store Annotation in a database.
    D. Specify the features for which annotation will be created.
    E. Specify if the annotation is to be feature linked or not. If not, uncheck the 'Feature Linked' check box, click the open folder icon, and specify the path and name of the new annotation feature class.
    F. Click OK.
    G. Click Convert.
  5. Convert the geodatabase feature class and Annotation feature class to a CAD file using the Export to CAD tool.
    A. Navigate to the ArcToolbox > Conversion Tools > To CAD toolset.
    B. Double-click Export to CAD.
    C. Select the feature class and annotation feature class as the input features.
    D. Select the CAD output type.
    E. Specify the output file location.
    F. Click OK.
Article ID: 000007092
Software:
  • ArcMap 9 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
