Summary
This article describes the steps required to establish a connection to Autodesk Forma (formerly Autodesk Construction Cloud) from ArcGIS Pro.
Before establishing a connection, ensure that the following prerequisites are met:
- Have an Autodesk Forma account with access to the desired projects.
- The ArcGIS Pro application must be installed and authorized in Autodesk Forma cloud.
Procedure
- In ArcGIS Pro, on the Insert tab, click Connections.
- Select New BIM Cloud Connection.
- In the Add BIM Connection dialog box, type a name for the new connection, and click OK.
- Sign in to the Autodesk account when prompted.
- Review the requested permissions and click Allow to authorize the application.
- The new BIM Cloud Connection appears in the Catalog pane.
- Expand the connection to access the available Autodesk Forma projects and hosted files.
