HOW TO
Connect and run SQL queries to a PostgreSQL database from Python
Summary
Connecting to PostgreSQL databases from Python provides the ability to run essential SQL queries that can be utilized in geoprocessing tasks.
Procedure
Instructions provided describe how to connect to a PostgreSQL database and run SQL queries from a Python script.
  1. Download and install the appropriate psycopg2 module for the installed Python release (for example, Python 2.6, 2.7, etc.):
    http://www.stickpeople.com/projects/python/win-psycopg/
  2. Import the module in the Python script:
    import psycopg2
  3. Make a connection to a PostgreSQL database by passing in the appropriate user/password to the following connection string:
    connection = psycopg2.connect(host='prod', database='sde', user='sde', password='sde')
  4. Define a parameter to access the cursor method:
    cursor = connection.cursor()
  5. Create a query string and pass to cursor method:
    cursor.execute('select * from PARCELS WHERE OBJECTID < 70000')
  6. Create a for loop and print results
    for query in cursor:
    print str(query)
Article ID:000011670
Software:
  • ArcMap
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
